0 Members and 1 Guest are viewing this topic. Read 5569 times.
Hi all,I solved an incredibly annoying problem recently - I was getting skips/stutters when I listened to my FLAC files via my Squeezebox Duet. I thought the problem was due to wireless dropouts or poor buffer performance on the part of the server and/or controller. But it was actually due to the fact that I had started to re-rip all my music to (very large) FLAC files stored on an external USB 2.0 hard drive. I noticed that my smaller .ogg files did not have the problem at all, and that the FLAC files also did fine if I moved them to my Laptop's internal hard drive and streamed them from there. So the stream from the USB connected external HD was the culprit. The solution is very simple - check your laptop and your external HD for eSATA connectors (they are labeled). If both have it, you are in luck, simply buy an eSATA cable and hook it up that way, done.If your laptop does not have an eSATA connector, you can buy a plugin card. My Toshiba laptop has an ExpressCard Slot, but some laptops have an PCMCIA slot, so just double check yours before heading out to the computer store (or newegg.com). If your external HD does not have an eSATA connector, you will have to buy a new HD, no way around that.Hope this helps others that might be having the same frustrations.
...Oddly enough, when I had 300g and 500g external HD's, I didn't notice a problem either....
