FS: VH Audio Cyro Treated Pulsar Digital Cable
0 Members and 1 Guest are viewing this topic. Read 976 times.
jholtz
« on: 12 Nov 2008, 03:34 am »
I'm offering a 1.5 meter Cyro treated VH Audio Pulsar digital cable for sale. I'm revising my system and no longer am using it. It is one of the best sounding digital cables I've heard. From the VH Audio website:
"The Pulsar™ interconnect utilizes a FINE (28 AWG), SINGLE high-purity BARE copper center conductor, surrounded by a solid FEP Teflon™ dielectric. During the R&D phase, a solid Teflon™ dielectric was found to be superior to a foamed dielectric, because the thickness of the dielectric can be applied and controlled to a MUCH tighter tolerance, resulting in a highly uniform impedance and more consistent density of the dielectric. This was found to be CRITICAL, when using with high performance digital components and component video applications. Also, the cable doesn't "egg-shape" to the extent that coaxes with foamed insulations do. This means more uniform impedence consistency along the length of the cable. This is what also what we believe promotes the very neutral and resolving presentation when used in analog applications.
The double shielded design of the Pulsar Interconenct consists of a foil and SILVER-plated copper braid. The silver plated braid adds the benefit of a low impedance path to ground (helping to minimize ground loops), and preserves the high-end "sparkle" missing in many copper-based analog IC's. The use of the single fine guage BARE copper center conductor eliminates the brightness that may be found in many designs that utilize silver plated copper signal conductors.
The raw Pulsar wire is also deep cryogenically treated with a special process developed jointly with American Cryogenics and VH Audio.
The standard finished Pulsar interconnects are terminated with Eichmann Gold Bullet plugs and use a specially manufactured ALUMINUM metal housing, to ensure a fully shielded design. This means more durability vs. the standard plastic version of the Bullet Plugs."
Pictures can be seen here: http://cgi.audiogon.com/cgi-bin/cl.pl?cabldgtl&1231644660&item
The cable is in perfect condition and looks new. It sells for $102 plus about $10 shipping new.
I'm offering it for $75 Paypaled to your door in the lower 48 states.
Thanks for looking!
Jim
