Technics SL1200 mods
0 Members and 1 Guest are viewing this topic. Read 8961 times.
sunshine
« on: 11 Nov 2008, 10:21 pm »
Anyone have any experience or care to give an opinion?
             http://www.soundhifi.com/sl1200/index.htm
Wayner
Re: Technics SL1200 mods
« Reply #1 on: 11 Nov 2008, 11:06 pm »
Kevin at KAB does the same stuff, here in the states. He offers several mods which are great values IMHo. www.kabusa.com
Wayner
TheChairGuy
« Reply #2 on: 12 Nov 2008, 02:22 am »
From another topics on the SL-1200 a couple weeks back: http://www.audiocircle.com/index.php?topic=59954.20
Airborn
« Reply #3 on: 12 Nov 2008, 06:19 am »
Here's my list of SL-1200 mods I'd like to try, taken from a post in another thread here a few weeks ago.
Anyway, I already have a list of upgrades to try on the new SL-1210 (sick since its only 3 weeks old).  I don't include the tonearm rewire since the SL-1210 M5G has upgraded wiring already and I don't think the outboard power supply and strobe disabler are on the list for now.
1. KAB tonearm fluid damper http://www.kabusa.com/frameset.htm?/m1200.htm;
2. Mapleshade 4" thick finished maple platform with Isoblocks http://www.mapleshaderecords.com/audioproducts/platforms.php, although maybe now I'll consider your Maple cutting board gal with some cut in half racquet balls underneath (the cutting board, not her) ;
3. Parts Express footer spikes http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=240-715;
4. KAB record clamp (the cheap rubber one with built in bubble level) http://www.kabusa.com/frameset.htm?/m1200.htm;
5. LP Gear Zupreme Headshell http://www.lpgear.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LG&Product_Code=LPGZHEAD&Category_Code=HEADSHELLS,
maybe with an AT-150 MLX attached to it  ;
6. Way down the line I may try the SDS Isoplatmat w/a Herbies on top, but I am still not sure those are worth it over the stock rubber mat flipped upside-down
I figure this wish list should satisfy the upgrade urge for at least 6 months, maybe longer
rare_heat
« Reply #4 on: 12 Nov 2008, 05:32 pm »
Hi guys, I have modded two of my Technics and they sound great. I actually am trying to trade one of my Rega arms for an SME 3009 or 3012 to see how that sounds. I would like to try some isolation feet next as well. I use a Michel record clamp too.
JimJ
  • Ut Prosim
« Reply #5 on: 12 Nov 2008, 05:57 pm »
*snip*
Cool pictures :)
rare_heat
« Reply #6 on: 12 Nov 2008, 06:02 pm »
Hey, thanks. Yeah, both have the OL adapters. They do what they are supposed to. A guy on ebay sells some nicer ones for a bit cheaper. I would have gone with them if they were available at the time. He makes one for an SME arm aswell.
TheChairGuy
« Reply #7 on: 12 Nov 2008, 06:07 pm »
Hi rare_heat...welcome to AC  :D
I see one of your arms has the Michell counterweight, the other does not.  Did it benefit performance having it?
I, too, run a Technics Sl-1200 with the Origin Live adaptor....now shorn with an Origin Live Illustrious Mk. III tonearm.
Despite the $3000 arm and every upgrade from KAB (and replaced stock feet and platter mat) I can only get similar levels of performance from it versus my venerable JVC QL-F6.
British-based Sound HiFi (owner Dave Cawley) thinks it may be the stock Technics regulator...maybe he is on to something there  :scratch:
(btw, I have the Sound Supports armboard adaptor for Linn/JELCO arms, too, and they are very nice looking lightweight aluminum.  I've not used it as yet (need to get a JELCO arm nut not a size they have down at the hardware store), but it's quite handsome in a different way than Origin Live's.
Are you in the UK?
John
rare_heat
« Reply #8 on: 12 Nov 2008, 07:16 pm »
Wow, that is frustrating isn't it? My goal for these decks is to have good sounding mixes, and they do the job very well. I would like to get an SME arm so that I can switch between DJ and MC listening/ripping carts. I eventually would like to get a VPI scout for listening and ripping.
One arm is heavily modified by myself with a Technoweight, internal and external rewire, and Eichmann silver bullets. The other one was modified by OL and it has the structural upgrade and internal rewire with Eichmann copper plugs. I think I like the sound of the OL arm better (maybe because I spent more for it  :?) but there is very little difference.
I modified my stock regulator so that it no longer fights me when I am speeding up or slowing down the platter with my hand. I wonder if his mod has a similar effect.
I am in California
jonners
« Reply #9 on: 13 Nov 2008, 12:06 pm »
  I would think not. Mods to the PS and regulator are usually aimed at improving the sound through getting better speed stability and control.
  John
