X-Over placement guidelines
0 Members and 1 Guest are viewing this topic. Read 1341 times.
Voncarlos
  • OB5s in Stripes
« on: 10 Nov 2008, 04:11 am »
What are the guidelines for placement of the crossover within a box?
For instance, should the components all be at the bottom.
Can they be split up and some parts be at the top?
How far away from the speaker magnets should they be, et cetera?
I am aware of how the foil inductors should be oriented.
JimJ
  • Ut Prosim
Re: X-Over placement guidelines
« Reply #1 on: 10 Nov 2008, 06:13 am »
I'd probably mount it close to wherever the binding posts are...
Danny Richie
« Reply #2 on: 10 Nov 2008, 08:17 pm »
E-mail me and I'll send you pics of an early OB-7 network (real similar) that was installed into the bottom of the box. I did a two layer board (stacked). One board holds the network for the mids and one holds the network for the tweeter and lower woofers.
