Correct xlr output print on BCD-1
0 Members and 1 Guest are viewing this topic. Read 1444 times.
Daniel Datchev
« on: 8 Nov 2008, 09:54 pm »
Hi James,
I wonder if it is correct the print connection guide for the pins on the back of my player.
The print says that G(ground) is on the right but in Wikipedia and BP-26 there is on the left.
I`ve checked the manual and the on-line manual to see is it correct.
I know there are some differences between US and Europe in connections.
Daniel
  • The Demo is Everything!
    • http://www.bryston.com
Re: Correct xlr output print on BCD-1
« Reply #1 on: 8 Nov 2008, 10:50 pm »
Hi James,
Daniel
Hi Daniel,
I will check with engineering on Monday for you.
james
Daniel Datchev
« Reply #2 on: 8 Nov 2008, 10:53 pm »
Hi James,
tnx I remembered where was said about the differences,it is Marantz site and it is the position of hot and cold are switched.
Daniel
Daniel Datchev
« Reply #3 on: 11 Nov 2008, 08:00 am »
Hi James,
I want to add that the description in the manual is OK,
but the print scheme on the back and in manual is not correct
Daniel
« Reply #4 on: 11 Nov 2008, 08:04 pm »
Hi Daniel,
I checked into this and the XLR print connection on the back of the CD Player is incorrect.
Thank you for catching that - we will correct it immediately.
james
