TJ Full Music 300B, 211, 805 and 845 tubes available through Grant Fidelity !
0 Members and 1 Guest are viewing this topic. Read 4927 times.
iGrant
Announced at RMAF 2008, Grant Fidelity has officially become the distributor of the wellknown TJ Full Music tubes in both Canada and the US. Current stock includes 300B series, the 12AX7 and 12AU7 and will expand to other models soon. Competitively priced with 12 months peace-of-mind warranty on selected models.
Contact us for more info.
Ian
« Last Edit: 31 Dec 2008, 06:28 am by iGrant »
iGrant
Re: TJ Fullmusic 300B tubes available through Grant Fidelity !
« Reply #1 on: 25 Dec 2008, 08:21 pm »
We now have the new TJ Full Music 805, 845 and 211's :) Info will be up on our site over the next few days.
Ian
iGrant
Re: TJ Full Music 300B tubes available through Grant Fidelity !
« Reply #2 on: 31 Dec 2008, 06:27 am »
Info is up on the new TJ FullMusic 805, 845 and 211.
http://grantfidelity.com/site/catalog/57/vacuum_tubes
There is some other very new tubes there too, which we will be announcing soon.
Ian
nullspace
Hi Ian,
Can you cofirm whether the 845s and 211s have thoriated tungsten filaments or oxide coated filaments? It's my understanding that if its the later the standard 10V 3.25A filament supply would need to be modified as oxide coated filaments would only draw around 10V 1A. Thanks for your help.
I'm beginning work on a 211 amp and it's nice to know that there will be once again be current production tubes available.
John
EDIT: I'm a dope. On the 845 page at your website it clearly says oxide coated filaments and 10V 0.6A. I had only looked at the 211 page. In that case, I'll change my question to: Any chance that Grant Fidelity will begin carrying Shuguang 845B and 211B with thoriated tungsten filaments? Thanks.
iGrant
Hi John,
Yes these tubes are designed around modern amp designs and are not a direct replacement for the RCA amp designs. It is supposed to be a simple amp mod to use the TJ's. Rachel is actually working on this and documentation has been translated into English and should be up on the TJ site soon.
We are working closely with both Shuguang and TJ to get the 'hard to get' tubes out on the market with different flavours. The Shuguang 211, 805's and 845's are out of stock at the factory for the highest quality and premium matched pairs, we will get some as they are made again to the spec we expect.
Ian
nullspace
Thanks Ian. I will absolutely be keeping an eye out for news from Grant Fidelity.
John
