Bugle - only getting 1 channel.
0 Members and 1 Guest are viewing this topic. Read 1420 times.
rysonaudio
« on: 7 Nov 2008, 09:25 pm »
Novice question. I just completed a bugle kit and I am having a problem. Left channel is strong, right channel barely audible.
I thought I may have had the opamps incorrectly installed. I have the chips situated with the circle on the opamp orientated with the (top left) square terminal on U3, U2, U1. Pins to ground I am getting around 9v. at that terminal and at bottom right pin also 9v. The pins in between all 0v. Its like this on all 3.
Is that correct?
What else should I be checking?
hagtech
    • http://www.hagtech.com
Re: Bugle - only getting 1 channel.
« Reply #1 on: 8 Nov 2008, 11:23 pm »
If one channel is working ok, then it isn't power supply.  Would be a non-solder joint or a wrong value resistor.
jh
jcg0322
« Reply #2 on: 15 Nov 2008, 01:34 am »
Send the unit back for analysis at no charge to Jack Gallagher.
You will be reimbursed for shipping.
No problem.
Jack
