FS : ** Acurus RL-11 Preamp & A250 Amp **
0 Members and 1 Guest are viewing this topic. Read 4314 times.
dee1949_0
« on: 7 Nov 2008, 08:42 pm »
_______________for Local pick up in Washington, DC ONLY - Cash on pick up ........Price .........$775.00
_______________they are in Mint condition and I would like to keep it that way.
******************************* Acurus RL-11 Preamp - MINT condition With REMOTE *******************************
....The RL-11 Preamp offers exceptional musical fidelity without sacrificing any accuracy. Completely solid state in design, it provides accuracy,
consistency and reliability. The RL-11 provides the wide band frequency response,
very low distortion and complete phase accuracy that is only possible with advanced solid stage engineering. Open, airy crisp sound.
Read some reviews at
http://www.audioreview.com
and find out what owners think. It is probably the best sounding preamplifier in it's price range.The manual can be downloaded form :
http://www.klipsch.com/products/discontinued/details/rl-11.aspx
Specifications:
20Hz- 20kHz Frequency Response, 0.05% THD, 95db SN Ratio, 60 mV
Input Sensitivity, 47 ohms Output Impedance, Input Impedance: 10 K ohms, 8 volts Output voltage,
6 pair single-ended inputs,4 pair single-ended Analog Outputs,
(2 pre-out, 2 tape out) One 5 volt Output Trigger, Silver contacts,
1% metal film resistors, Dimensions 17" x 8" x 3.5"
*************************************** Acurus A250 amplifier - Mint condition ***************************************
........The Acurus A250 2 channel amp delivers 250 watts of clean power per channel at 8 ohms to your speakers. Output is 350 watts at 4 ohms.
This is an outstanding amplifier. Do a Google search of "Acurus A250" and you will find a multitude of positive reviews of this amp.
Truthfully, I have never seen a negative review of it.
It is in Mint condition, fully functional. It's a cool running amp which is surprising for a high-powered amp of this size.
A250 Specifications:
Rated Power - 250 watts into 8 ohms, 350 watts into 4 ohms
THD - 0.06%
S/N Ratio - 110dB A Weighted
Input Sensitivity - 1.2V for full output
Input Impedance - 20K ohms
Read reviews at:
http://www.audioreview.com/cat/amplification/amplifiers/acurus/a250/PRD_116262_1583crx.aspx
dee1949_0
Re: FS : ** Acurus RL-11 Preamp & A250 Amp **
« Reply #1 on: 18 Nov 2008, 07:02 pm »
....anybody interested???
