Effective Qts of 2 speakers in series
0 Members and 1 Guest are viewing this topic. Read 3638 times.
ttan98
« on: 7 Nov 2008, 08:22 am »
If you connect 2 speakers whose impedance is 4 ohm in series, you get a total of 8 ohms, also the 2 similar speakers will be mounted in a H-frame similar to Orion, ie back to back, what would be the effective Qts?
My guess is a total of 2*Qts or just 1*Qts. Anyone wants to give me an explanation.
Also if any think think this series combo would not work well please explain. The Fs of each speaker is less or equal to 30Hz. If you need more info please leave a message here.
Thks.
scorpion
Re: Effective Qts of 2 speakers in series
« Reply #1 on: 7 Nov 2008, 09:43 am »
MJK has a good explanation for the T/S-parameters with two drivers here: http://www.quarter-wave.com/General/Two_Drivers.pdf .
The Qts will stay unchanged.
If your amplifier can handle the 2 ohm impedance from parallel driving you will gain 6 dB in effeciency compared to series drive.
/Erling
David Weil
« Reply #2 on: 7 Nov 2008, 10:35 am »
The biggest drawback in series connection results from speaker tolerances. Look at a typical impedance curve and you can imagine what happens, if two coils form a voltage divider, when the impedance is not exactly matched at each frequency. The frequency response of each speaker will become uneven. If you are lucky and the speakers are not totally different, they add up to an even response again.
The efficiency is not changed, because you need the same amount of power for the same SPL. The SPL for a given voltage is lower, because less current flows, so you need to adapt your crossover for a linear frequency response over the voltage.
