Insight Amps
0 Members and 1 Guest are viewing this topic. Read 2248 times.
chuckm
Insight Amps
« on: 7 Nov 2008, 02:36 am »
Looking for a new amp and was wondering if anyone heard the Insight 440H or others with Quad 2805's. Also considering Modwrights new amp if anyne has heard that.
robinje
Re: Insight Amps
« Reply #1 on: 7 Nov 2008, 05:09 am »
I haven't heard the new ModWright power amp, but it does look nice from the pics I've seen.  It also costs about four times what an AVA Insight 440H costs, I think.  Ouch...   :o
avahifi
    • http://www.avahifi.com
Re: Insight Amps
« Reply #2 on: 7 Nov 2008, 02:26 pm »
Looking carefully at the specifications for the Quad 2805 (8 ohm nominal impedance, 86 dB sensitivity, and 55V RMS max allowable input voltage  - -  slightly less than 200W per channel) it would appear that either our Insight 440 or Fet Valve Ultra 350 amplifiers would be outstanding choices to compliment the performance of these excellent speakers.  You would not need the "H" version of the Insight amplifier as the 2805 would be an easy load for it.
Note that at a recent AudioKarma show in Detroit, we lent an Ultra amplifier to an adjoining room where the owner was downcast because his highly regarded and very expensive loaner amplifier had failed trying to drive his pet speakers, two sets of completely restored KLH 9 full range electrostats, two speakers connected in parallel on each channel, talk about a very nasty load.  The Ultra performed flawlessly for the show and the owner of the speakers told us he had never heard them sound that good before.
The prices are pretty close ($1699 for the solid state Insight, $1949 for the hybrid Ultra).  I think your choice of preamplifier would enter into the decision.  If you are using a soft sounding vacuum tube preamp, I would go for the Insight amplifier, with a more aggressive preamp, choose the Ultra.  If money is no object, then I would lean towards the Ultra.  Both amplifier drive full range electrostatic speakers easily and with outstanding musicality full range.
Thanks for your interest.
Frank Van Alstine
Dan Kolton
Re: Insight Amps
« Reply #3 on: 7 Nov 2008, 03:16 pm »
I heard the KLH 9s to which Frank refers at AudioKarma.  With Frank's electronics, I thought they sounded "Best in Show".
avahifi
Re: Insight Amps
« Reply #4 on: 9 Nov 2008, 05:17 pm »
For my reader's information, ChuckM called me yesterday and ordered a Fet Valve Ultra 350 amplifier.  The deciding factor was its very high input impedance (compared to the Insight amp) which makes it a better choice with his passive preamp.
Thanks so much as always for your support and thanks for the order, Chuck.
Frank Van Alstine
chuckm
Re: Insight Amps
« Reply #5 on: 9 Nov 2008, 08:16 pm »
Thanks Frank,
Can't wait to get it. For other interested - the system was Quad 2805's with a Bent Audio preamp (passive). Right now using a First Watt F3 which is of course a problem with the Quads. Input is all files from computer and Peter Daniels Audio Sector USB DAC.
Frank, thanks for all the time you spent talking to me and helping me deciede over the other amp I was considering.
