0 Members and 1 Guest are viewing this topic. Read 3052 times.
PC's have what is called the "K-kernal" which drops bits, inherently, in windows, regardless of everything. Foobar2000 does as much as it can to work against this, but an Apple still have the advantage that it does not suffer from any drop.
Is bit perfect jitter free? Even if you get your ducks in a row, will they keep strait line and march on time? Is this possible with noisy SMPS?
www.silentpcreview.comdamn good recommendations on all quiet componentry...I recently bought an Enermax Modu82+ 625W power supply as recommended on that site - I cannot audibly tell the PC is powered up apart from visual indicators (LED on the case), even from half a meter away. it helps that my motherboard controls the fan speed, but its amazingly quiet (under a measured 20db in use).
