Agisthos, Brad,
Some very interesting questions and comments in your posts, and Brad, of the many posts I have seen over the years perhaps yours comes closest to describing how I designed the AKSA and related products.
All Aspen products were designed by ear. Not just mine, but others too, some of them veritably glowing golden in broad daylight! If this seems ad hoc, consider the folly of designing solely for good specifications, and then steadfastly insisting the product is good even when it sounds terrible and consumers vote with their feet! This has been the case for many years, with scores of amplifiers designed for good specification in the hapless pursuit of 'good sound'.
In truth, high end engineers have at times taken on an almost surreal priestliness to their craft, and this would be admirable if it had delivered the goods. A justifiable view might now be that we are measuring the wrong things, and still setting our clocks by the measurements, and flailing about wondering why the sonics are below par. I have taken a very pragmatic view, engineered something very simple in most cases, and then by careful dimensioning, component choice, and layout, 'voiced' something which sounds very good. I must stress that others have believed in my approach, encouraged me, many of the AKSAphiles here in fact, and in particular Darl Singh of NZ, whose input with the GK-1 was worth his weight in gold. (Tragically he has lost considerable weight since those days, Darl we need to talk!!)
The odd thing I've found has been that after the voicing, the careful layouts and choices, the exhaustive listening tests, Robert L. Jones of Newport Beach CA did some measurements on the 100W AKSA in December 2002 and came up with this (thank you sincerely, Robert!):
Total Harmonic Distortion at 1 kHz into 8 ohm resistive load using HP339 Distortion Analyser
0.2% at 0.1W; 0.08% at 1W; 0.007% at 10W and same to clipping.
At 10kHz and 1W into 8R resistive: 0.042%; at 20kHz and 1W: 0.045%.
Not exceeding 67dB below (0.045%) at any frequency to 20KHz for 10W to 95W into 8R. Distortion profile is second and third harmonic, both 'musical', with all other distortion components, including intermodulation, immeasureable and below the noise floor.
These results were obtained about a year ago on a stock AKSA 100WN, and show that the voicing procedure has, if anything, enhanced the engineering specification, which is, frankly, to die for. I believe these figures demonstrate that an audio amplifier can be designed using sonic criteria and still meet rigorous engineering parameters, and that this design approach is at least as valid as any other. Of particular pride to me was the distortion profile, something I have been rabbiting on about for years, as it is this profile which the ear seems to home in on, rather than individual levels of harmonics or absolute magnitude of the distortion, which as we know with SET amplifiers is very high, often over 2%.
The power supply is very important, and adds the icing on the cake to a good design by ensuring very low noise injection into the power rails. It's not well understood, but it appears that high speed switching noise from power diodes creates a wash of RF spikes which enter the amplifier and prevent it from delivering high resolution in the audio band. It makes good sense that an amp cannot deliver sonic detail if it is noisy; what is not realized so universally is that even if this noise is ultrasonic detail will be lost in the audio band.
Transformers can and do make a difference. This was never clear to me until I had some very expensive double C cores made for a 100W amplifier. At first the sound was disappointing, for two months in fact. Then something clicked, and now the sound is just cosmic. For the life of me, the only thing different about this amp (which I built to order) was these transformers. However, and I'm reserved about this, it does appear there is an inexplicably long delay 'breaking in', whatever that means. I have no explanation for this, but I will probably sit in parks with my fist under my chin thinking on it for years to come........
In closing, Brad comments on cost. I could probably build an amplifier for the devotee which costs thousands in parts alone. No problem. Give me carte blanche and I will built it coated in platinum!! (I won't enjoy it, though, because it goes completely against my frugal nature!) But I cannot guarantee it will please everyone, since tastes do differ, and it will be very poor bang for the buck. I've said this before, but most in DIYers want an economical, spare design which beats the big names - fair enough, we all want the best we can get - and I wouldn't sell too many!!
Hugh
Hugh
