0 Members and 1 Guest are viewing this topic. Read 35726 times.
I'd be more inclined to get 4 of these: http://tinyurl.com/5uyo5cpocket the $65 savings per side (you were talking stereo, weren't you?) and enjoy the fact that my amp now behaved as if it were 10 times more powerful!
If the Goldwood are 18 inches and only $49, with no specs there’s likely a catch. Magnetar found it (but was able to get a refund I hope). If they're for MIs, it probably wouldn’t have much Xmax.MagnetarThanks, but the Warrior 15s only have an Xmax of 0.25", 6.3 mm. I’m after something to use down to about 30 Hz. The Mach 5 IXL 18"s have an Xmax of 22 mm 0.9 inch.The Eminence Alpha 15A has high Q and low price on its side, and are reasonable quality, but Xmax is only 3.8 mm, so you need > 10 Alpha 15As to equal one Mach 5 IXL 18 . .In Vd, two Eminence Kilomax Pro-18 equals about one Mach 5, but they are about the same price.Any knowledge of the Mach 5’s?
There is a good collection of dipole woofer distortion test here:http://www.mfk-projects.com/woofers.htmI also recently did a nonlinear distortion measurement of Eminence Alpha 15A:http://www.diyaudio.com/forums/showthread.php?s=&threadid=132665
