0 Members and 1 Guest are viewing this topic. Read 29008 times.
Darrel really makes some nice baffles using many techniques mentioned in the past about the important features for OB. A lot of these ideas have been used before, but to see it all together in a commercial product is pretty neat. The baffles aren't just the usual MDF with a pretty veneer and gloss. All his baffles are wood instead of MDF. Drivers/baffle connections are damped, or in other cases, magnet mounting is used to minimize vibrations. Sand filled bases are common now, and he has done sand filled borders for the entire baffle as well. His wife, Diana, puts a bit of woman's touch to custom design options (WAF anyone?). Darrel chronicles many of these builds on the forums, and the speaker building forums of the Hawthorne Audio site should be considered a great resource for OB ideas (and not just about Hawthorne products). One of his current builds is really something to see (http://www.hawthorneaudio.com/forums/viewtopic.php?f=2&t=2399). AKfest 2008 threads should give some more public opinions about the Hawthorne Sterling Silver Iris speakers. I believe it was the only show those speakers have made a public appearance at, and it did receive a lot of praise, along with the equally impressive Eddie Vaughn Carina amp.
Hi Windchaser,Detailed info and pics of the rest of my system are on the first page of a thread I started on the Hawthorne Forum to document my experience with the Trios. Here's a link to it: http://www.hawthorneaudio.com/forums/viewtopic.php?f=2&t=2393&p=33716#p33716
without reading through all the postings at Hawthorn can you quickly summarie how you achieve the x-over between the 15" woofers and the midrange. eg1. x-over freq.2. biamping3. paralleling the woofers4. Any equalization or delay on woofers and midrange. Thanks.
Doak,I assume the DQ-LP1 is a commercial analog low pass(also high pass as well) unit? Easily adjustable for for freq and the slope steepness?
Quote from: ttan98 on 11 Nov 2008, 12:25 amDoak,I assume the DQ-LP1 is a commercial analog low pass(also high pass as well) unit? Easily adjustable for for freq and the slope steepness?The Dahlquist DQ-LP1 is a vintage unit and is an active variable low pass/passive high pass crossover. The 2 subwoofer outputs are variable from 40-400Hz from the front panel.All controls and switches are accessible from the front panel. There are 2 Filter Bypass switches that bypass all internal circuitry to send the full audio signal to the mains, while still sending the variable low frequency’s to the subwoofers. Also, there are 2 volume level controls for the subwoofers, 2 Equalizer Dials that you can adjust from +0 to +5 db, and 2 Frequency dials to very the subwoofer outputs from 40Hz to 400 Hz. All rear inputs and outputs are RCA's. There are 2 inputs for the left and right channels. 2 Low outputs to the left and right channel subs. 2 High outputs to the mains. Also there are 2 outputs for Center Channel Lo out.The low pass filter is 18 db per octave,and the high pass is 6 db implemented by plugging in capacitors/resistors for each channel. It is an "elegant" design and IMO has not been surpassed nor equaled by current offerings.Pic from a current EBay Auction (not mine!):
Those are beauties Doak. Look forward to hearing them when you get them dialed in to your liking. Thanks for the updates on your progress.BR
Very nice speakers!I wonder if they can be done with a less wide baffle, yours do NOT fit my room.
Quote from: Telstar on 13 Nov 2008, 07:37 pmVery nice speakers!I wonder if they can be done with a less wide baffle, yours do NOT fit my room.Then a 10 in. driver version may be just your "cup o' tea." The 10' Sterling Silver Iris driver/crossover is just becoming available, the 10" Silver Iris and 10" Augie bass drivers have been for sale for some time now:Hawthorne Audio Driver Page: http://hawthorneaudio.com/drivers.htm
Quote from: ttan98 on 13 Nov 2008, 10:49 pmHi Doak,I already exchanged a couple of mails with Darrel. My doubts are on how many 10" drivers would be needed to create a similar sound to the Sterling Trio.Otherwise perhaps just a tighter baffle...
