Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Bugle for 78 playback
0 Members and 1 Guest are viewing this topic. Read 1622 times.
schnak
1 Nov 2008, 11:53 pm »
Hi,
I have a bunch of Columbia Masterworks and RCA Red Seal 78s. I would like to change the resisters in my Bugle to make the eq correct for the old labels. I have a mono Orophon 78 cartidge. I will use one channel for one label eq and the other channel for a different one. I have looked at the filter values tool and am confused. I cant find bass zero info, all the info I find on 78 eq only list bass turnover. Same with treble. Anybody done this or can help?
hagtech
Facilitator
Re: Bugle for 78 playback
6 Nov 2008, 06:38 am »
www.hagtech.com/pdf/bugpro.pdf
jh
schnak
Reply #2 on:
7 Nov 2008, 08:40 pm »
Hi Jim,
Thanks thats what I need. That way I can use it for 33 and 45 rpm records also. I thought thats what the pro did. Now I need to make a digikey order. Thanks Jim.
woodsyi
Volunteer
Always Look on the Bright Side of Life!
Reply #3 on:
7 Nov 2008, 08:52 pm »
I got one for 78's. Works just fine.
Other Stuff
Hagerman Technology
hagtech
