Dimensions of Torus RM20 Unit: Is the owner's manual or website correct?
0 Members and 1 Guest are viewing this topic. Read 2016 times.
john1970
Dear Bryston,
I am looking at purchasing a Torus RM20 unit in early 2009 and I am measuring my current stereo cabinet to ensure that it will fit.
My rack opening is 22" x 17.5" x 10" (W x D x H).
The Torus Manual states that the RM20 (Model No. A024-ACB-A1AB) is 19" x 15.5" x 5.25" (W x D x H).
However, the website states that the dimensions are 19" x 17" x 6.25" (W x D x H).
Which measurements are correct?  I can probably squeeze the unit in if it is 15.5" in depth, but 17" is probably too deep.  I really hope the manual is correct.
John
  • The Demo is Everything!
    • http://www.bryston.com
Dear Bryston,
John
Hi John,
I will go measure mine and be back to you shortly.
james
Hi John,
My RM-20 Torus is:
19" x 16" x 6" (with feet)
The front has a curved silver center section on the faceplate and that sticks out about another 3/4 inch making it 16.5 inches.
james
john1970
James,
That leaves me with only 1" front-to-back clearance.  There is a cut out on the back of my cabinet so it is possible for me to put the cords through the back opening.
Do you have a technical drawing for the RM20?
This would allow me to be able to tell the distance between the back outlets and the bottom of the unit and would allow me to tell if the outlets line up with the back opening of my cabinet.
Best,
John
James,
Best,
John
Hi John,
Email me at [email protected] and I will send you the PDF of the 12 page brochure showing the backs.
james
john1970
Hi John,
My RM-20 Torus is:
james
James,
Thank you for the dimensions and PDF file.
My opening is 22.5" W x 17.5" D x 10" H.  I will have to place the RM20 unit on a 2" platform to allign the outlets with the hole in the rear of the cabinet thus reducing the overall height to only 8".  There are glass doors on the cabinet, but I generally leave them slightly open when listening to music.  Should I be concerned with venelation for the RM20 unit?
Please advise and thank you,
John
Hi John,
I have a 15 amp Torus unit behind glass doors in my upstairs TV/Stereo system and I have never had an issue with heat.
james
john1970
James,
Thank you for the feedback.
Best,
John
