0 Members and 1 Guest are viewing this topic. Read 17745 times.
Hi Robin ~You are quite right... my apologies!!!!I removed my thoughts from my above post... and again... sorry for my misunderstanding.It is strange what can happen sometimes in ones mind when reading a post... or reading anything for that matter... there is always the potential for a misreading... admittedly... I was tired.Warmest Regards ~ Richard
The lack of a well defined stereo imaging is due to out of phase front and back sound waves. Note that because of the relatively low mass and un-braced nature of open baffles, the baffle itself produces significant amount of sound. Also note that due to the large surface area of most open baffles, reflections of sound off the baffle from the other speaker (in the case of stereo applications) can further diffuse/confuse imaging.
Is an open baffle speaker difficult to place, ie more difficult than a rear ported speaker?
With an open baffle speaker, is sound quality as dependent on room treatment as in driver selection?
What is a good mainstream open baffle loudspeaker I could go listen to as an example of the tech? Where should I go listen?
How is the bass extension in a 2.0 listening environment?
Is there an issue with separation between the sound of the open baffle portion of the speaker and the sealed sub beneath often seen in this type of speaker, alla electrostats?
I'm not a big fan of electrostats because, it might just be me, but the sub and the mid/hi have a totally different sound character.
But I have a weird room, my speaks have to go in basically a corner, I have been looking at front ported towers.
Since a dipole has a sound radiation pattern that has nulls at 90 degrees from the dipole axis,
To BigRick,You might also consider corner horns, like Klipsch or Pi-speakers or homebrew if you have good corners and need to use the corners. I don't think OB is the solution to all music enjoyment and your situation might be a perfect time for another solution like a corner horn.
Hornshoppe is another one to consider for corner loaded (or not) horns.
Quote from: opnly bafld on 1 Nov 2008, 05:24 pmHornshoppe is another one to consider for corner loaded (or not) horns.Lin Are you talking about those little single driver speakers? If you are those aren't horns.
I am using the Hawthorne Audio Silver Iris. The 15" coaxes can go down to 50hz or so on their own and they have a nice midbass punch.
