AKSA 100N grounding question
0 Members and 1 Guest are viewing this topic. Read 1434 times.
JimB
« on: 19 Nov 2003, 06:16 pm »
I'm going with a wood enclosure first because I don't want to attempt a metal one right now. My question is where do I hook up the ground wire? I'm referring to the third wire with the mains that goes to the wall. Also, do I need to worry about running ground to the heat sinks as they are insulated by the wood.
Sorry if this has been covered before. I just find this forum a wonderful resource. Thanks in advance for anyone kind enough to reply.
Jim
AKSA
    • http://www.aksaonline.com
« Reply #1 on: 19 Nov 2003, 08:34 pm »
Hi Jim,
Hook 'em to the heatsinks, and any metal plate you have elsewhere in the enclosure!  Nothing more.....  That'll do it fine!
Hugh
