Newer vs Older 2B LP
0 Members and 1 Guest are viewing this topic. Read 1855 times.
94cdnm3
« on: 30 Oct 2008, 05:26 pm »
Hello fellow Bryston fans!
I am currently using an older 2B-LP in a bi-amped configuration and am quite satisfied with the performance. It is probably almost at the end of its 20 year warranty but I am quite confident in its reliability and am not concerned.
 :However, I am curious as to whether a newer (<5yrs) 2B-LP is sonically improved over an older one like mine. There must have been some changes to the componentry if not circuitry over the years. I have noted from a recent ad that recent versions have a detachable power cord versus the fixed cord of older models.
Thank you in advance for any helpful responses to my query. Cheers!  :D
Mag
Re: Newer vs Older 2B LP
« Reply #1 on: 30 Oct 2008, 10:49 pm »
The Baby Bryston built like the big guys!
Yep, it has a detachable power cord.
I bought my 2B-LP two years ago, it was manufactured on 1/11/06. The purpose was to power my center channel speaker in my MC/HT. Previous to the 2B-LP the center channel was powered by my Yamaha RX-V2200.
What I wanted was for my center channel to blend better with my Paradigm Studio 100 v2, particularly the tweeters, powered by a 3B SST. My concern buying the 2B-LP was that it might not match the sonics of the 3B-SST.
Finally on powering up, it was like the 2B-LP filled a gapping hole in the center soundfield. As if the Yamaha was doing nothing in comparison to power the center speaker.
If there is a difference in sound between the 2B-LP and the 3B SST, I can't hear it based on my MC/HT setup. They seem to match perfectly with my Paradigm Studio speakers.
Specs:
Output power: L/R 81,82 watts RMS, bridged 229 watts RMS
IMD- L/R .00175%,.00262%, bridged .00266%
THD
20 Hz: L/R .00472%, .00460%, bridged .00591%
200 Hz: L/R .00288%, .00293%, bridged .00229%
2K Hz: L/R .00296%, .00301%, bridged .00202%
20K Hz: L/R .00565%, .00528%, bridged .01379%
Noise- Balanced L/R -105 db, -100 db, bridged -108 db
