NOH with gain?
0 Members and 1 Guest are viewing this topic. Read 2132 times.
rwalton
NOH with gain?
« on: 19 Nov 2003, 01:56 pm »
Hi John,
I thought there are/were S&B 102 trannies that provide some gain (I believe it was +6dB).  Maybe I overlooked it on the Bent site, but I was just wondering if the 6 dB gain option is available in a NOH kit?  I so, can you elaborate a bit?  Thanks in advance!
Rick
John Chapman
    • http://www.bentaudio.com
NOH with gain?
« Reply #1 on: 19 Nov 2003, 10:31 pm »
Hello!
Yes - you are right. All current tx102's offer the +6db gain option. The NOH kit (and pre-built) has a place for the gain switch and I should add it to the standard options list as I do supply them from time to time.
The +6 mode works very well provided your sources output impedance is not too high.
John
Jamiehughburr
Price of NOH 6 db gain option
« Reply #2 on: 25 Nov 2003, 09:10 pm »
Dear John: How much is the 6db gain option for the NOH? :?
John Chapman
NOH with gain?
« Reply #3 on: 25 Nov 2003, 09:37 pm »
Hello!
The +6db optiion adds $20.00 to a pre-built NOH and $15.00 to a kit.
Thansk!
John
Jamiehughburr
Most reasonable--thanks
« Reply #4 on: 26 Nov 2003, 02:48 pm »
Dear John: Thanks for the prompt reply. Sounds most reasonable. I'll add that to my NOH list of options. Best. Jamie  :!:
