Castanet Output Transformers
0 Members and 1 Guest are viewing this topic. Read 1835 times.
flocchini
« on: 28 Oct 2008, 11:37 am »
Has anyone "upgraded" the output transformers on the Castanet?
Bob
flocchini
Re: Castanet Output Transformers
« Reply #1 on: 30 Oct 2008, 11:47 pm »
I should have been more specific. I am debating if I should experiment with output caps (currently Dynamicaps) such as the Mundorf Jim (tubesforever) uses or look into a transformer from ElectraPrint (the Hammond done with part silver) Best and thanks.
MusicMtnMonkey
« Reply #2 on: 2 Nov 2008, 08:23 pm »
I wondered the same thing about buying custom transformers to upgrade the sound in a CASTANET.  If you go through with it, I'd love to know how it goes!
poseidonsvoice
    • 2 channel/7 channel setup
« Reply #3 on: 3 Nov 2008, 12:52 am »
You most definitely can, and you most definitely will get a different sound. You will have to specify the exact turns ratio to Jack Elliano so he can custom wind you a transformer. Of course, it may or may not fit on the same circuit board that was designed for the Hammond. The output transformer is the crux of any amplifier. In a parafeed preamp,the output capacitor is as well. The bypass cap will make a difference too. See my gallery for the parafeed preamp I built years ago for ideas if you want to diy on your own. FWIW, Jim's design hits the price/performance value quite nicely. However, If you can stretch your budget the sky is the limit. If I were upgrading, I would change each of these items one at a time. The output transformer first, next the parafeed cap, next the bypass cap.
Best,
Anand.
flocchini
« Reply #4 on: 4 Nov 2008, 04:17 pm »
Anand - thanks for the input
I will definitely check your gallery
MusicMtnMonkey
« Reply #5 on: 4 Nov 2008, 05:07 pm »
Thanks for Sharing Anand!  That's some really nice looking DIY equipment :drool:
Inspiring, need to finish acquiring materials so I can work on my CASTANET  aa
