0 Members and 1 Guest are viewing this topic. Read 46048 times.
Just wanted to revive this thread because this attenuator caught my interest. Was this buffered passive pre ever produced?
I wonder how that myth would sound with ultra low impedance battery power fully powering the units circuits and remove the ac mains and internal power supply totally (if possible). I tried this on a LDR from DIY Paradise, the Eva, and the results were unbelievably better across the board. LDR seems touchy to ac mains distortions. The Eva was kinda touchy, sometimes it would go nuts and I would have to reset it but maybe that was a bug that needed a fix in the programming that was fixed afterwards but it did sound fabulous. Bettered other TVC's I have used in the past, some costing well over $5K with buffers and special battery supplys. This could also be related to a impedance differential that occurs from component to component that another poster had mentioned. If thats the case, you could get the tvc's primary/secondarys impedance changed to be more suitable by the manufacturer if they willing do that on a custom basis , instead of adding in additional compensation circuitry afterwards into the already very sensitive analog line level domain.
it doesn't have the sound like the same device as it should, considering the same a-formers inside. less transparency, less extension in bass, more reserved sound.truth to be told i don't know what stacking is in both units - and that may affect the sound in a very big wayi have no time to investigate tap-x in more depth, but i'd also love to resolve a mystery why a simple 1 input 1 output AVC in a wooden box sounds so superior - and i found that only when i got used to a remote control of tap-x
Are you saying your 1 to 1 DIY Passive is better than the autoformer tap x?
