0 Members and 1 Guest are viewing this topic. Read 46050 times.
Silonex is the premium brand of LDRs for audio according to the Lightspeed thread. Silonex has some application notes to make a diy VC. http://www1.silonex.com/audiohm/levelcontrol.htmlNote the feedback and LEDs in series (in Fig 15) to assure matched current to each. This is easier than hand matching the LDRs to use voltage input as with Lightspeed.Their website nav is flakey now, so here is the sitemap to learn more.http://www1.silonex.com/sitemap.htmlMe too wondering about the Myth
If there are any AC users from the UK, there will be a Myth LDR preamp for a demo tour there soon. If interested in, pls PM me with your sending details.No plans for the States, sorry.
The buffer in the Myth helps provide a very low output impedance that makes it more widely compatible.
I'm in the UK, and the Myth preamp has been in my system for the past few weeks. I’m very impressed with the full and detailed sound. I’m shortly going to have to send it back to the manufacturers’ representative, so I’ve now ordered one for myself and sold my transformer volume control which was also very detailed but sounded thinner and less appealing (possibly, I’ve been advised, as a result of an impedance mis-match with my power amps). I don’t know how the Myth compares with the “lightspeed” preamps from Georgehifi or the Eva from DIYParadise They are more minimalist and that may possibly be an advantage, but I want the convenience of five inputs and I could not use the Georgehifi version with my power amps because their input impedance is no more than 10kohms. The buffer in the Myth helps provide a very low output impedance that makes it more widely compatible.
Another perspective/offering on the type of PRE being discussed in this thread; its a longish thread and the details trickle out, but there is enough on the first page to explain the basic design which uses LED's and LDR:http://www.audiophiletalk.com/cgi-bin/yabb2/YaBB.pl?num=1254751267
here's one thread which indicates a reason one may rather choose any other brand besides myth:http://www.diyaudio.com/forums/analog-line-level/80194-lightspeed-attenuator-new-passive-preamp-290.htmldoug s.
Now if I could only use the Lightspeed internally in my active that might be the ticket.
that's not a problem - seen a few DIYed tube amps using LDR attenuators, some were preamps and some were poweramps with a basic LDS passive volume control . very smart solution as the plain LDR attenuation circuit is very cheap, under $50. even some big names are doing it, i've read on DIYaudio forum that payl hynes has a tube preamp with LDR attenuation in his production.as to the issue of drive and weight, i replaced my music first copper with myth with massive improvement particularly in this area. however i really like dave slagle autoformers - they certainly have less drive than the bufferred myth but his AVCs can sound smoother and more "polished" (not everyone's cup of tea but sometimes i like that) and i like to have that option in my room. so as i said before, my choice are myth and bent tap-x. music first copper, promitheus, earlier bent TVCs, placette etc - that's clearly behind. in my room and in my system (tubes and horns).
Hey man long time no talk. You and I have had a lot of experience with passives going back to the Promitheus threads. I value and trust your opinion about passives. time for more research on my end . If you say the Myth has more of a full sound I'm interested. Thanks.charles
If you like the buffer idea, what about one of these? http://doddaudio.com/BatteryPoweredTubeBufferPreamp.aspxthread on AC:http://www.audiocircle.com/index.php?topic=75028.0
