tube amp noise
0 Members and 1 Guest are viewing this topic. Read 1847 times.
yeldarb
tube amp noise
« on: 27 Oct 2008, 04:22 pm »
Yeah, I know, this probably isn't vintage, though it isn't being made anymore.  My NORH SE9, single ended pentode makes a little noise in the left channel when I first turn it on.  Sounds like a dirty potentiometer, but the pot is not in use and is blocking all input.  Noise disappears with warm up and then the amp sounds just fine (great, actually).  Do I have a tube going bad or is it possibly a capacitor?
I'll change output tubes from channel to channel to see if the noise moves this evening, but I'm looking for opinions.
JimJ
  • Ut Prosim
Re: tube amp noise
« Reply #1 on: 27 Oct 2008, 05:27 pm »
Dirty pins, maybe?
yeldarb
Re: tube amp noise
« Reply #2 on: 30 Oct 2008, 03:56 pm »
I rotated the output tubes to no avail.  Then I rotated the 12ax7 pair and the noise was gone.  So, dirty pins it must be.  I am surprized.  Pleased, but surprized.  I was going to swap out the Mullard 5ar4 rectifier next and I hated to think that was causing problem.
