SongTower and bass managment settings?
0 Members and 1 Guest are viewing this topic. Read 2463 times.
elee532
« on: 21 Oct 2008, 01:00 am »
Are folks configuring their SongTower's as small or large speakers? What crossover frequency are you using? I'm having a hard time getting my STs to blend with my sub (Hsu VTF-2).
Thanks for any info.
zybar
Re: SongTower and bass managment settings?
« Reply #1 on: 21 Oct 2008, 02:16 am »
Large.
I am using 60Hz as the crossover point to dual homemade subs.
George
fsimms
« Reply #2 on: 21 Oct 2008, 02:31 am »
When I was playing with the SongTowers,  I used my preamp to cut off the speakers low bass response and cross it to the sub.  The Tact preamp adjusted the phase and delay of the sub.   I also set them up at Raj's house and set them as small with his receiver.   He is happy with it.
Bob
Nuance
« Reply #3 on: 21 Oct 2008, 02:02 pm »
For movies - Small crossed over at 60Hz
For music - Large run full range.
elee532
« Reply #4 on: 21 Oct 2008, 02:20 pm »
Thanks Nuance. Is your sub active when you run your mains as large for music?
Nuance
« Reply #5 on: 22 Oct 2008, 03:28 pm »
It can be, but I don't usually turn the "double bass" feature on unless the recording is grossly lacking in bass.  In other words, I can run the speakers full range and use the subwoofer at the same time, but I don't usually do this.
