FS: Cary 280SA "V12r" Triode/ultralinear switchable!
0 Members and 1 Guest are viewing this topic. Read 1554 times.
AVguy
Winter is coming and the cold can penetrate the inner sanctum of your listening room. I have just the thing to warm you up the Cary Audio Design 280SA amplifier also affectionately known as the "V12. This is actually the upgraded and more expensive V12r model.
The Cary V12r has six EL34 tubes per side that will provide 100 watts in ultralinear and 50 watts in Triode mode. You flick a switch and pick the one that sounds best in your system! (and you get a very cool Jaguar red paint job to go with that V12r name (sorry no flames on the paint job ;-)
Tubes are: twelve EL34s, two EL84s and two 12BZ7s
The V12r has four and eight ohm taps as well as both balanced and single-ended inputs.
Check out the manual through the web address provided above. (Some genius put in a MEGApixel pdf file, so it's kinda' slow to load)
This amp is in perfect condition. It was used at one audio show and has been in a box for four years; it's just like new!
You can have this one for $2700.00 o.b.r.o.
Money Order Bank Draft or Wire transfer preferred. If buyer wants PayPal buyer pays fees.
Includes:
original box and packing materials
You can check my Feedback on Audiogon (spit) under "Golden_ears")
Email me for photos or see my ad with photos at: http://www.canuckaudiomart.com/details/102157-cary_audio_280sa_v12_amp/
http://www.caryaudio.com/pdfs/manuals_archive/Cad280SA_V12.pdf
« Last Edit: 8 Nov 2008, 04:47 am by AVguy »
