Naim preamp with D200
0 Members and 1 Guest are viewing this topic. Read 2307 times.
sharpei
« on: 17 Oct 2008, 10:39 am »
Hi.  Has anyone tried another preamp make with CIS monoblocks?  Is this safe?  Can i just plug the balanced plug into the D200 (real newbie here) without creating an electrical danger?
I look forward to details of the PLC1 Mk II but until funds allow, I'm stuck with my existing preamp......
Thansks
richidoo
Re: Naim preamp with D200
« Reply #1 on: 17 Oct 2008, 12:44 pm »
Welcome to AC Sharpei!!!
Assuming your preamp and amp both have balanced (XLR) connections then you should have no problem doing what you propose. Just turn power off to the amp first to avoid thumping your speakers. It is pretty difficult to harm a CIA amp, they are well protected.  If you have a high gain model amp CIA (intended for a passive preamp) then you may find that your volume control has a small range of motion before it gets too loud.
Hope to see you posting on AC in the future.
Rich
sharpei
« Reply #2 on: 21 Oct 2008, 05:53 am »
Thanks for the response, Richidoo.
