Cheap single driver full range 5.1 system....can do?
0 Members and 1 Guest are viewing this topic. Read 2674 times.
Christof
I'm looking to throw together a small, quick and easy diy 5.1 system for occasional HT use for about $500 (sans subwoofer).  After much scouring of the net for diy designs, I think I may have it narrowed down to the FR125SF full ranger from CSS.  At $70/channel(driver) with minimal filter component expense I should be sub $100, can this be beat?  Anyone have experience with this full range driver?  Any other recommendations for a full range single driver speaker with parts budget of $100/channel?  Here is the design I have in mind CSS  Speaker to be driven with a Panny SA-XR57
c.
JimJ
  • Ut Prosim
Re: Cheap single driver full range 5.1 system....can do?
« Reply #1 on: 15 Oct 2008, 09:27 pm »
That'd definitely be a good place to start, although with those cabinets I think low bass extension in bass-heavy soundtracks may be limited somewhat. Larger floorstanders like BIB's would extend lower, and would provide an easier transition to a sub if you do decide to get one in the future.
Bob in St. Louis
« Reply #2 on: 15 Oct 2008, 10:22 pm »
Some of those PartsExpress DIY "thingys" look pretty attractive.
If memory serves, they had 5.1 build plans and parts list recently.
Bob
lord_glum
« Reply #3 on: 16 Oct 2008, 12:25 am »
Honestly before i read this post i thought of same driver.  At least with a single driver that is.  I assume you want to stay single driver?  I have built some 4" fostex systems for less, but the CSS has nice power handling capacity so i would take it over the fostex drivers (bass should be better).
I was actually looking at some of these boxes earlier today....
http://www.planet10-hifi.com/boxes-CSS.html
thanks,
Jvo
Christof
« Reply #4 on: 16 Oct 2008, 12:36 am »
LG
Weird, we have crossed paths many times today :scratch:  I was all set to do the CSS FR125 driver speakers and then I ran across these from 8Ball Audio, I wish I would have never seen them.  Walnut cabinets on Stainless stands, hats off to that guy!!!!
lord_glum
« Reply #5 on: 16 Oct 2008, 12:44 am »
Yeah and I have more questions for a later date...
I will say the look good; really good.  Nice sense of style.  I wonder what drivers are used.  That and they are less than $100 per speaker?
jvo
JimJ
  • Ut Prosim
« Reply #6 on: 16 Oct 2008, 01:36 am »
jvo
Looks almost like a Tang Band full range. They're not bad, a solid low-budget choice :) TB has a big line of stuff, Parts Express sells a lot of it...
As cool as those cabinets look, I wouldn't expect much midbass :(
Christof
« Reply #7 on: 16 Oct 2008, 01:37 am »
......I wonder what drivers are used.  That and they are less than $100 per speaker?
jvo
Not going to happen for $100 or less, he is using Jordan JX92S drivers at about $175 a pop but they sure are sweet looking.
JimJ
  • Ut Prosim
« Reply #8 on: 16 Oct 2008, 01:40 am »
jvo
Ah, I thought to myself that they looked like Jordans, but I figured LG was saying that they were less than $100 instead of asking if they were, whoops :P
There's a TB 4" that has a cone almost identical-looking to the JX92S.
lord_glum
« Reply #9 on: 17 Oct 2008, 12:57 am »
If they were less than $100 i would have to order a set on principle. :thumb:
The only other question i have is does it have to be a single driver?
Jvo
Christof
« Reply #10 on: 17 Oct 2008, 12:44 pm »
Jvo
Must be a single full range driver
JimJ
  • Ut Prosim
« Reply #11 on: 17 Oct 2008, 01:32 pm »
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=15128
A friend of mine's build log for a pair of BIB's for FR125's :)
One of these days if I have an amp that has enough power I'd like to try some.
JP78
