0 Members and 1 Guest are viewing this topic. Read 6243 times.
"D" Up above is a big one because your amplifier's performance hinges on it. Low power amplifiers do not drive low efficiency speakers well at all. Keeping the efficiency rating high ensures superior amplifier compatibility.How a speaker delivers is very important. I've seen speakers profess a 20-20k response and sound lousy! Be careful about the speaker technology you choose. For example, ribbon tweeters sound different than soft dome, which sound different than compression horns and so on. They all have a different slant on the speaker's tonality. I'm not a speaker builder- so check with those who are and remember: Google is your best asset.
Basics for choosing new equipment:Before spending thousands on a complete system, consider ALL your options and do not, under any circumstances go past ones that are unfamiliar to you. I see too many people skip over new products and companies simply because they are new. Making assumptions is a good way to pass up on good equipment. Getting back on the topic: Here are some things I have learned:1. Start with the speakers. The speakers are more important than anything else in the system. I can't stress that enough. There are too many variables to cover now, so here are four big ones:A. Select the widest frequency responseB. Get speakers big enough for your room. Small speakers in a big room isn't good. C. Frequency response isn't everything. Quality of delivery is just as important or more so. D. Do not get low efficiency speakers initially. Get something around 1w=90db or better. "D" Up above is a big one because your amplifier's performance hinges on it. Low power amplifiers do not drive low efficiency speakers well at all. Keeping the efficiency rating high ensures superior amplifier compatibility. How a speaker delivers is very important. I've seen speakers profess a 20-20k response and sound lousy! Be careful about the speaker technology you choose. For example, ribbon tweeters sound different than soft dome, which sound different than compression horns and so on. They all have a different slant on the speaker's tonality. I'm not a speaker builder- so check with those who are and remember: Google is your best asset. 2. The AmplifierThere are as many amplifiers as there are speakers! Now more than ever, delivery is of paramount importance and not the frequency response. Most amps have a 20-20k frequency response BUT not a single model will portray that response in the same light! Different kinds of amplifiers:A. Solid State: Uses transistors throughout its constructionB. Hybrid: A marriage of tube and transistor technology. Typically either tubes or transistors are dominant in these designs. C. Tube: Tubes use used throughout. They may have a solid state power supply, but the signal path will consist of 100% tubes. Use Google to search the various tube vs transistor blogs, writeups and threads. Naturally, look in Audiocircle too. Each technology has their strengths and weaknesses, depending on what you expect from your new system. A note: The more expensive you go, the closer these technologies will sound alike. Manufacturers seem to reach a consensus of what sounds 'perfect' as price increases and better performance is expected as a result.
Face plates. Face plates have to match.If I have to do it all over again, I wouldn't get any gear that did not match my Noir theme. The sound really suffers when you have to stare at silver plates.
Quote from: Niteshade on 14 Oct 2008, 11:29 amBasics for choosing new equipment:An ironclad, no-questions-asked, 30 money back satisfaction guarantee should be confirmed before any purchase. This applies to amplification, source, IC's, etc. If buying pre-owned gear, this is not practicable in most instances. It should certainly be weighed in the decision making process, though.JMHO,Jerry
I believe the speaker/room interface is number one. The size of the room, necessary/allowable placement, seating position, "goals" such as even dispersion in a room or specific to "a spot", listener preferences (multi-ways, OBs, line arrays, hi-eff, single drivers), reverberant characteristics/whether treatments are an option, and other factors dictate what speakers have a better chance of working in a room. Screw this one up and nothing upstream will fix it. As always it's best to try before you buy in your room but that's tough to do these days. Having an escape plan is always smart if things don't go as hoped.Then, an amp to properly drive that speaker in that room becomes paramount. Certain amps like certain speakers and vice versa. Also listener preferences play an important role.
Basics for choosing new equipment:Quality of delivery is just as important or more so.
90DB+ SPEAKERS,,,THAT REALLY LEAVES OUT A LOT OF VERY GOOD SPEAKERS MEL
