Niteshade Audio: Photos of Past Projects
0 Members and 1 Guest are viewing this topic. Read 7771 times.
Niteshade
    • Niteshade Audio
« on: 14 Oct 2008, 10:43 am »
There are several more photos to come. The Baldwin/Fisher combo turned out to be an impressive amplifier. Fisher 500C output transformers are fantastic quality while the Baldwin transformers and chassis proved to be exactly what a  35 watt/channel 6L6 amplifier deserves. All kinds of reserve power! The frequency response is linear without a hint of low-voltage sag fatness or other anomalies thanks to the dual 5U4 rectifiers.
Stay tuned for more...
Niteshade
    • Niteshade Audio
Re: Niteshade Audio: Photos of Past Projects
« Reply #1 on: 27 Oct 2008, 06:54 pm »
It's not too often that such an old amplifier makes it through time this clean and well preserved. The knob on the power transformer's bell housing is a primary tap for selecting 110,115,120,130v line voltages. All the insides were replaced. Gutting took around a day! How does it sound? Sweet! Very clean and natural with a fantastic bass response, clear highs and a perfect midrange. Power output is set to around 8 watts/channel. She runs very cool and quiet.
pardales
« Reply #2 on: 27 Oct 2008, 07:50 pm »
Nice looking stuff, keep the pic's coming.  :thumb:
Niteshade
    • Niteshade Audio
« Reply #3 on: 29 Oct 2008, 12:39 pm »
These amps are some examples of my Classic Series rebuilds.  Making vintage equipment come alive is a thrill! Having unique equipment can't be a bad thing. There are several more photos to come that will be placed on my web site and lsited here as well.
Audiovista
    • Vista-Audio
« Reply #4 on: 29 Oct 2008, 12:48 pm »
Yeah, keep the pics coming Blair.  :thumb:
Are you doing restorations of vintage amps too?
Niteshade
    • Niteshade Audio
« Reply #5 on: 30 Oct 2008, 11:16 pm »
A pair of ***BIG*** old Baldwin amplifiers being tested.
jon_010101
« Reply #6 on: 31 Oct 2008, 12:59 am »
I've a pair of those Baldwins in my basement.  I'd suggest dumping the 12AX7 paraphase for a "real" driver stage.  But the power supply is fantastic - choke input with huge iron.
Niteshade
    • Niteshade Audio
« Reply #7 on: 31 Oct 2008, 10:42 am »
What did you notice about their paraphase circuit? I'm still testing them. I noticed some white noise and believed that control over the woofer is a little unnatural.
Niteshade
    • Niteshade Audio
« Reply #8 on: 31 Oct 2008, 10:55 am »
Boris,
I have restored a few. It depends on what the state of the majority of components is. If they look weathered, have heat rash or condensation damage- then everything is gutted. Some amps are constructed so that it's difficult to unravel the leads. I don't mess with those unless it's just a few caps and resistors. Doing a 100% rebuild with the manufacturer's original circuit is feasable too.
I wonder how many hours it took to assemble something like a Fisher 500C?
Niteshade
    • Niteshade Audio
« Reply #9 on: 1 Nov 2008, 06:01 pm »
LE-100a with unique textured high gloss finish and solid nickle faceplate attached with four brass thumb screws.
pardales
« Reply #10 on: 1 Nov 2008, 06:09 pm »
Its great the you can arrange the tubes in different ways. I like them clustered like you have them pictured above in the Le-100a.
Niteshade
    • Niteshade Audio
« Reply #11 on: 1 Nov 2008, 07:24 pm »
There are several tube configurations available. The NS-100 has a single row with a driver tube in between the the tubes its driving. Keeping the power tubes separated as far apart as possible increases their lifespan. Having a dual row works well as long as the spacing is adequate. A few months ago I did a 5-tube stereo amp that had a "V" configuration. Looked great!
Niteshade
    • Niteshade Audio
« Reply #12 on: 2 Nov 2008, 01:50 pm »
15 watt/channel EL84 amplifier. Phase splitterless design, 5AR4 rectifier. Driver tube: 6SN7
Niteshade
    • Niteshade Audio
« Reply #13 on: 6 Nov 2008, 02:05 pm »
NS-100 Integrated Amplifier
The following options were added:
1. Variable negative feedback
2. Easy Adjust Bias, auto equalization
3. Universal primary Hammond power transformer
Niteshade
    • Niteshade Audio
« Reply #14 on: 7 Nov 2008, 12:04 pm »
Inside the above posted NS-100:
Niteshade
    • Niteshade Audio
« Reply #15 on: 13 Apr 2009, 04:25 pm »
An Amp I made around 2006. GIANT output iron promotes signal purity. This amp was rated for about 30 watts per channel and the iron is rated for 60 watts.  :D
Niteshade
    • Niteshade Audio
« Reply #16 on: 27 Apr 2009, 01:27 pm »
Niteshade
    • Niteshade Audio
« Reply #17 on: 1 May 2009, 03:13 pm »
Our designs are diversified electronically and physically. Some of these, such as the model listed above this post was created using a vintage box. Pre-punched sockets in all the right places plus heavy gauge steel make for an excellent UPS-proof amplifier that looks great!
Most of our new products center around a 17x10 steel enclosure. It's big enough for several all our models and provides room for different component configurations.
If you would like something special- let us know!
