0 Members and 1 Guest are viewing this topic. Read 10427 times.
The Bass traps are a 16 inch and 12 inch tubes of stiff fiberglass, shaped in tubes.
How big of a trap would I need to deal with nulls in the 70-100 hz region?
ah, so it's really the depth that matters then as to what kind of frequencies are absorbed?
The tubes are simply rigid fiberglass in a tube shape with mdf on top and bottom
I'm thinking now that I should open the existing ones back up and put in some mineral wool for additional absorbtion.
The wife busted me on pulling the speakers out already, not sure if they'll stay pulled out from the wall that far.
QuoteThe wife busted me on pulling the speakers out already, not sure if they'll stay pulled out from the wall that far.The typical audiophile approach of pulling speakers far out from the walls is not necessarily the best method. The only way to know for sure where your speakers should be for the best bass response is to measure using REW while you experiment with placement.--Ethan
Have you tried a sweep with the main set of speakers and listening position shifted to the left/right a foot or two? Or with the sub on a different wall?
As regards the GIK's, they come in 3.5" and 5" thickness, I think that's right. You want the 5" ones, I believe. They may have something other than that they would recommend. It's been awhile since I've visited their site.
