Rocky Mountain Show.
0 Members and 1 Guest are viewing this topic. Read 3404 times.
John Chapman
    • http://www.bentaudio.com
« on: 9 Oct 2008, 12:28 am »
Hello!
Although I won't be down to the show this year I wanted to put a plug in for some of the OEM partners I work with who will be there. Here are the ones I spotted right away - please let me know if I have missed you!
Exemplar Audio - TAP Hybrid modules inside John's reference pre-amp.
Marriott Main Lobby ~ Lupine
http://exemplaraudio.com/
ModWright Instruments, Inc. - programmed chips for level control.
Marriott Tower - Level 10 ~ 1010
Marriott 5th Floor ~ 529
Marriott Tower - Level 9 ~ 9007
http://modwright.com/
Red Wine Audio - Vinnie has the record for the number of remote kits! I lost count.....
Marriott 5th Floor ~ 543
http://redwineaudio.com/
Response Audio / 5th Floor, Room 511 - Stepper remote kits used for level control.
http://responseaudio.com/
Ultra Fi Electronics - They are doing some custom builds with Slagleformers inside! Extreme stuff indeed for an OEM to use.
Marriott Denver Tech Center / Room 437
http://www.ultrafiaudiodesigns.com/
Atma-Sphere Music Systems, Inc.  - They have just started using the remote kits to add remote control to their pre-amps.
Marriott Main Lobby ~ Evergreen Ballroom A
Marriott Tower - Level 11 ~ 1100
Marriott Tower - Level 11 ~ 1130
http://www.atma-sphere.com/
Hope I did not miss anyone! Have fun at the show if you are going - should be a great time. One of these years I'll make it down there......
Thansk!
John
« Last Edit: 9 Oct 2008, 08:14 pm by John Chapman »
