What is the finest kahartago monoblock upgrade level ?
0 Members and 1 Guest are viewing this topic. Read 2198 times.
hertz
Been thinking about upgrading from my Stratos basic to the khartago monoblocks. Like the stratos monoblocks which can be upgraded to regular , extreme, extreme se and then the glass ceiling versions, what are the options with the khartagos ? Cost ?
Haoleb
Re: What is the finest kahartago monoblock upgrade level ?
« Reply #1 on: 7 Oct 2008, 05:10 am »
I believe that the highest level khartago you can get is with the pilton transformer, 120,000uf capacitance and whatever better parts are used on the board. The case cannot accomodate a second transformer like the stratos can. If you really want the best I think the Stratos extreme mono SE's are the way to go. But of course... Call Klaus :)
hertz
« Reply #2 on: 7 Oct 2008, 06:06 am »
Will this be a real upgrade over the basic stratos with caps upgrade ?  :)
Anyone has done an upgrade like this ? I am not too sure about the stratos mono-blocks due to space and other constraints.
lazydays
« Reply #3 on: 7 Oct 2008, 06:39 pm »
I'd save some money and have Klaus do a full tilt rebuild of your basic Stratos amp. It'll be close to the samekind of money you'd spend for a nice pair of mono Kartagos, but probably sound better with the bigger transpormers. I think there's even a way to build two monos in the same base, but of course with a smaller power supply. I think Klaus and I'd be talking trade up to a pair of mid level mono blocs which will set you up for a better upgrade path.
gary
hertz
« Reply #4 on: 8 Oct 2008, 04:17 am »
When you say "rebuild of the stratos", do you mean an "stratos extreme" ? Is there a " glass ceiling" upgrade to the stratos stereo ? The kismet stereo seems to be priced at around 2200$.Is this the way to go  ?  :wink:
