Clarinet input pot - can it be 100K ?
0 Members and 1 Guest are viewing this topic. Read 1801 times.
SoundBound
« on: 2 Oct 2008, 10:43 pm »
The design of the Clarinet line stage calls for a 50K pot as volume control.  Can this be substituted with a 100K without altering the Clarinet's performance or operation?  I am thinking of using a motorized potentiometer from Alps and may be able to easily get a 100K version.
hagtech
Re: Clarinet input pot - can it be 100K ?
« Reply #1 on: 3 Oct 2008, 04:51 am »
Should be ok.  Change the balance pot too.
jh
tubesforever
« Reply #2 on: 19 Oct 2008, 07:50 pm »
Jim,
Since I am using only a single 50k attenuator, instead of the balance and attenuator, do I need to add additional loading before the attenuator to balance my Clarinet?    If so, should I select 25k or 50k ohms for the loading resistor?
Cheers!
hagtech
« Reply #3 on: 21 Oct 2008, 07:26 am »
Probably best off just bypassing the balance control.
jh
