USB Off-Ramp Turbo 2 - need help on what and how to buy
0 Members and 1 Guest are viewing this topic. Read 2415 times.
ead
hi
I have a DAC, and I want to get sound out of my PC
Right now I am using SPDIF from my sound card (optical or COAX)
now
I have heard that jitter isn't a good thing
Right?
So
Will using a device like this can remove the jitter and make my sound be better?
Also
I want to get the sound out of my PC and into the DAC (it has both COAX and Optical)
and I have seen that the  Off-Ramp have some options for upgrade:
Options include:
Captive S/PDIF coaxial cable with copper Eichmann Bullet-RCA Plug (standard)
Captive S/PDIF coaxial BNC output instead of Bullet-plug (75 ohm Neutrik BNC)
- no charge
AES/EBU output instead of S/PDIF coax - $150 additional
RCA jack instead of captive cable - $15 additional
AES/EBU jack instead of captive cable (must also have option 3) - $25 additional
Nextgen copper 75 ohm plug on captive cable - $120 additional
Nextgen copper 75 ohm jack - $60 additional
What should I take to get the BEST out of it ?
What are the last two ones? and will they improve something ?
Also
Is there other products or options for doing the same thing as getting sound out of my PC ?
Thank you for the help.
woodsyi
Re: USB Off-Ramp Turbo 2 - need help on what and how to buy
« Reply #1 on: 30 Sep 2008, 05:02 pm »
Getting Steve to put I2S on your DAC would be the best way with Off ramp.  If not, I would get BNC plug on your DAC.  Pace car is also a worthy option.
ead
« Reply #2 on: 30 Sep 2008, 05:10 pm »
amm
I don't understand
What are all those options? and what is the best one?
And why not using off-ramp and connecting it to my DAC with the coax ?
audioengr
« Reply #3 on: 30 Sep 2008, 05:35 pm »
amm
I don't understand
EAD - the Off-Ramp is being replaced soon with the Off-Ramp 3.  This will have several outputs and the only options will be:
1) Superclock4 - recommended
2) 5V I2S interface for Northstar and Stello
Orders that I'm taking now will be for the Off-Ramp 3.  Pricing will be similar, but I dont know it exactly yet, so same as Turbo 2 for now.
Steve N.
ead
« Reply #4 on: 30 Sep 2008, 05:45 pm »
Look
Some sties have like one or two DAC's, but here you have like 10 options and than sub options and so on  :green:
so
Can you futher explain me please?
I am sure to take the latestest version with the last firmware of it
But
I just want a simple thing, and want to do it the BEST way I can do, with out sending my PC to you or my DAC (mean no modding)
I want to take my pc, connect it to a device, what ever with spdif or USB, and than from that device connecting to my DAC using optical or COAX, so I get BEST sound possible with almost no jitter or any other problems
What can I get and how ?
Please explain me.
woodsyi
« Reply #5 on: 30 Sep 2008, 06:09 pm »
Off Ramp 3 with super clock 4 option would be your best bet for what you are asking given your conditions.  I2S protocol is better than SPDIF since a receiving chip is not needed to separate out the data stream and clock information.  Without that option, you have to deal with SPDIF.  I read that BNC gives you the best 75ohm connection needed for SPDIF and that the digital cable need to be of sufficient length to combat interference from bounced signals.
ead
« Reply #6 on: 30 Sep 2008, 06:12 pm »
what kind of upgrades are for it?
I have also seen there is the "ultraclock"
what is it? and what does it give? and what about the power PSU and cables and so on?
Thank you!
audioengr
« Reply #7 on: 30 Sep 2008, 07:18 pm »
Thank you!
Lets please take this to email.
Steve N.
