***SOLD***Dared VP-20 Monoblocks $475
0 Members and 1 Guest are viewing this topic. Read 5942 times.
Big Red Machine
« on: 26 Sep 2008, 11:31 pm »
I tried bi-amping with these and they didn't work for me.  Second owner.  Only used for a few hours.
Paypal preferred.  Original double box, manual, PS, umbilicals, and stock tubes.
« Last Edit: 10 Nov 2008, 02:24 am by Big Red Machine »
Big Red Machine
Re: Dared VP-20 Monoblocks $550
« Reply #1 on: 2 Oct 2008, 10:47 am »
Mariusz
« Reply #2 on: 2 Oct 2008, 01:12 pm »
More info please.
I am somewhat interested.
Mariusz
Big Red Machine
« Reply #3 on: 2 Oct 2008, 01:40 pm »
INTEGRATED/POWER QUASI-MONOBLOCK AMPLIFIER (PUSH-PULL)
TECHNICAL SPECIFICATIONS:
MAX OUTPUT POWER: 18Wx2
FREQUENCY RESPONSE: 20-20KHz (±1.5dB)
DISTORTION: ≤1%
SIGNAL TO NOISE RATIO: ≥85dB
INPUT SENSITIVITY: 300mV
INPUT IMPEDANCE: 100K Ω
OUTPUT IMPEDANCE: 4 Ω /8 Ω
SIZE: L285 X W140 X H140 MM
WEIGHT: 11.0Kgs/Pair
Vacuum Tube:
6P3P(6L6G)x4,12AX7x2,12AU7x2
http://www.daredtube.com/mini.htm
Double boxed, thick foam insert, manual, power cord, umbilicals.
Mariusz
« Reply #4 on: 2 Oct 2008, 05:04 pm »
Thanks Big Red,
I am on the look out for inexpensive SET amp (300b, 211, 845) in any condition for mods.
I will come back if unsuccessful.
Mariusz
Big Red Machine
« Reply #5 on: 10 Oct 2008, 12:56 pm »
Bump
Big Red Machine
« Reply #6 on: 16 Oct 2008, 03:12 pm »
bump
Big Red Machine
« Reply #7 on: 20 Oct 2008, 01:26 am »
bump
Big Red Machine
Re: Dared VP-20 Monoblocks $500
« Reply #8 on: 21 Oct 2008, 12:28 am »
$500 takes them
Big Red Machine
Re: Dared VP-20 Monoblocks $475
« Reply #9 on: 23 Oct 2008, 10:03 am »
lower price
Big Red Machine
« Reply #10 on: 26 Oct 2008, 11:44 am »
Shirley needs a low powered tube amp set up for her high efficiency speakers? :green:
Big Red Machine
« Reply #11 on: 27 Oct 2008, 06:41 pm »
bump
Big Red Machine
« Reply #12 on: 2 Nov 2008, 10:25 pm »
bump
Big Red Machine
« Reply #13 on: 6 Nov 2008, 01:16 pm »
bump
Dan Driscoll
« Reply #14 on: 7 Nov 2008, 04:58 pm »
Red,
Do you know what model year these are?
Big Red Machine
« Reply #15 on: 7 Nov 2008, 05:27 pm »
Maybe I could send the serial numbers to them and they might be able to identify them.  Assuming there are serial numbers.
I don;t believe they are more than 3 or 4 years old at the outside, being the second owner and all.
I can ask the seller how long he had them as well.
Dan Driscoll
« Reply #16 on: 7 Nov 2008, 05:34 pm »
Are the contacts on the tube sockets gold plated? If they are gold plated they the amps are 2006 models or newer. If not they are 2005 or older. I'm asking because there were some design changes for the 2006 model.
Big Red Machine
« Reply #17 on: 7 Nov 2008, 05:38 pm »
I can check when I get home.  Should I be scrapping or painting? :green:
Big Red Machine
« Reply #18 on: 7 Nov 2008, 09:43 pm »
Gold plated.  Hopefully that's a good answer.
Big Red Machine
« Reply #19 on: 7 Nov 2008, 09:46 pm »
