Amp for Aurum Cantus- Volla
0 Members and 1 Guest are viewing this topic. Read 2617 times.
dupo
« on: 26 Sep 2008, 06:47 pm »
Hello, I`m Searchin Power or Integrated Amp for this speakers, Waiting for your suggestions , thank you
PhilNYC
Re: Amp for Aurum Cantus- Volla
« Reply #1 on: 26 Sep 2008, 08:44 pm »
Aurum Cantus matches well with Cayin tube gear...they are both distributed by the same company (VAS Audio) and are often paired up in trade-show demos...
(disclaimer: I am a Cayin dealer)...
dupo
« Reply #2 on: 26 Sep 2008, 08:48 pm »
thank you for your answear, more answears please :)
max190
« Reply #3 on: 27 Sep 2008, 12:07 pm »
Bada DC-222
dupo
« Reply #4 on: 27 Sep 2008, 12:56 pm »
why bada? , Because you use it or Because you try it with the Volla?
some one try Volla with any amp that can be recommended?
max190
« Reply #5 on: 27 Sep 2008, 01:34 pm »
Yes, I own the Bada.
No, I have never listened to the Aurum's
kyrill
« Reply #6 on: 28 Sep 2008, 06:01 pm »
i suppose the aurum cantus have their ribbon tweeters installed
i have them and they sound much more livelier with tubes
dupo
« Reply #7 on: 28 Sep 2008, 07:36 pm »
Hi Kyrill,
Do you have the Volla? or another aurum cantus speakers? , what tubeamp do you heard with them ?
10q
kyrill
« Reply #8 on: 28 Sep 2008, 08:07 pm »
Hi Duppo
no i dont have the Aurum Cantus  total speaker
i "only" have their ribbon tweeters which are -when properly installed-  very very fast and almost distortionless.
but tweeters express from 2khz  a to 20 khz
this is an important domain
i would urge you to use tubes or the very natural sounding Red Wine 30.2 or 70.2 amps. they will sound very well with yr upper domain ( if yr speakers have ribbons)
dupo
« Reply #9 on: 28 Sep 2008, 08:52 pm »
kyr,
I dont think that 30W can move my tweeter (G1 of Aurum Cantus) and probably not my speakers as well.
NagysAudio
    • http://www.nagysaudio.com
« Reply #10 on: 29 Sep 2008, 02:55 am »
Rotel RA-1062 if your budget is under $1000
Used Goldmund SRI/SRI2 or YBA Integre DT if your budget is under $2000
kyrill
« Reply #11 on: 29 Sep 2008, 09:16 am »
the Volla is 88 db sensitivity
that will give you 98 db with a 10 watt amp, 101 db with 20 watts and some more with 30
which is very loud to my levels
depending on a larger room or you want to give a party with those speakers than 30 watts will not be enough
a hefty power amp may be beneficial for parties and big rooms and large orchestral works with sudden bursts in loudness
On the other hand tube power sounds louder than ss power, and some high end ss amps as well. the RW 30.2 also sounds (much) louder than its 30 watts suggests
normally i listen between 65 and 80 db which to me is loud
here is a reference list i keep for a long time but forgot the source
0-Threshold of hearing
10-rustle of leaves, a quiet whisper
20-average whisper
20-50-quiet conversation
40-45-hotel, theater between performances
50-65-loud conversation
65-70-traffic on a busy street
65-90-train
75-80-factory noise( light/medium work)
90-heavy traffic
90-100-thunder
110-140-jet aircraft at takeoff
110-130-threshold of pain
140-190-space rocket on takeoff
« Last Edit: 29 Sep 2008, 12:12 pm by kyrill »
