Cornet Question to Jim Hagerman
0 Members and 1 Guest are viewing this topic. Read 1664 times.
odermatt
« on: 26 Sep 2008, 03:09 pm »
Hello,
in line items:
- I studied various plans on your site and saw after V1A first line stage R9 and also called later on R204 (part of RIAA) 220 Ohms vs 10K which is a hell of a lot difference.
- can you give me a short statement meanwhile I will insert post for easy removing the R's and gve it a try as I do not have such measuring equipment to study the effects
With my best regards to Hawaii
Peter
hagtech
    • http://www.hagtech.com
Re: Cornet Question to Jim Hagerman
« Reply #1 on: 27 Sep 2008, 07:11 pm »
It's not really so much different, once put in perspective.  That resistor is a tweak to more precisely align equalization of the lower turnover.  It affects mainly the 50Hz corner, which has little affect on equalization accuracy in the midband and treble.  Mostly, you'll notice it as a gain change (~1dB overall).  It also puts in a slight boost in the bass.  Really, when you're working with 100k resistors and plate impedances, it's not so much.  Hard to explain if you don't understand the intricasies of network design.
Think of it this way, the government could increase your taxes by a factor of ten, but the resulting national debt would not budge.  Whether or not this resistor is 1 ohm or 10k ohm, it makes very little difference in the outcome.  You'll get far more variation just by rolling tubes.
jh
odermatt
« Reply #2 on: 28 Sep 2008, 09:01 am »
Thanks Jim,
I will try to measure and than try to input the values RIAA explanation in one of your posts and see what happens-meanwhile I will built a precise invers RIAA-I have have plenty of parts in stock-I think this will cover the answer and after some time I will understand The network basics I have all this papers on hand from Lipshitz eg eg eg .
But meanwhile the music have to be on.
Best regards
Peter
