Era D10 or Salk SongTower
0 Members and 1 Guest are viewing this topic. Read 1333 times.
sfteach
« on: 24 Sep 2008, 03:17 am »
I have decided to finally make the jump and build a system. I'm starting with speakers and am drawn to these 2 due to quality for money (and waf considerations). I listen to all types of music, but mostly jazz, rock, classical, and bluegrass/folk. I haven't done enough research on amps yet, but I am hoping to start with an integrated amp. I don't want to spend more than 3/3.5 total for now and probably won't upgrade anytime soon once I make my decision. Has anyone actually compared these speakers? I've heard the ERAs, but for obvious reasons, I have no idea what the SongTowers sound like...Any help/suggestions are appreciated!
golfugh
  • Dead Can Dance - Into the Labyrinth
Re: Era D10 or Salk SongTower
« Reply #1 on: 24 Sep 2008, 03:42 am »
Take a look at this thread (it has both in it):
http://www.avsforum.com/avs-vb/showthread.php?t=995082
golf
sfteach
« Reply #2 on: 24 Sep 2008, 11:33 pm »
Thanks, golf. That helps reassure me that i was leaning in the right direction.
« Reply #3 on: 25 Sep 2008, 12:19 am »
Sorry can't speak to the comparison factor, though can 2nd the value of the thread golfugh recommended. The info provided by funkmonkey, craigsub, & nuance over there, along with the general info here regarding Jim Salk's work were the basis of my Song Tower choice a year ago. Happy as the proverbial pig in slop with that decision.
If you're looking at primarily 2 channel, I'd recommend checking out the new AVA Insight Integrated to match with the STs in particular. My 2 channel is separates as I had Frank convert my old Hafler 220 into a Hafler 250EX (effectively the OmegaStar 260EX), were it not for that I'd probably have given the integrated strong consideration. The combination if you wanted Frank's remote control (recommended), depending on finish choice on the Song Towers would bring you in pretty much at your max budget, but I don't think you'd be disappointed on any level.
I also figure there's a reason Jim & Frank team up at RMAF, and other shows to showcase their wares, aside from regional loyalty. I believe there is a definite compatibility factor or much as I cringe a little at the term, synergy, with their respective products.
If you haven't already you should check out the Salk section here, 'Owners willing to Audition' thread. Not sure where you are, but you might find someone close enough with Song Towers to give them a listen. If there's no one listed in your area, post a inquiry.
Good luck in your search, and have fun.
funkmonkey
« Reply #4 on: 25 Sep 2008, 02:25 am »
I would choose the SongTowers, hands down.
But that is only my opinion.  By the type of music you mentioned, I would guess that you like the sound of acoustic instruments, and they sound exceptional on the SongTowers, as do vocals.  The ERA's sound good, but do not offer the detail that the SongTowers do.  Ask yourself if you listen to music as background, or do you like to be engaged by it.  For me the ERA's were not engaging, they were something that sounded pleasant.  The SongTowers made me feel moved by the music.  Good luck, and let your own ears decide what you like.
Funk
