Mobile Fidelity Carbon 3.5 cartridge review
0 Members and 1 Guest are viewing this topic. Read 3301 times.
chosenhandle
« on: 23 Sep 2008, 02:12 pm »
Jeff;
I think that you are the only magazine (or private party) that has publicly commented or reviewed the Mofi 3.5 Carbon cartridge. You sure gave it a rave review.
Although it has been a while, I am interested in learning more on that cartridge. Primarily, have you heard a Miyabi Standard or 47? Being made by Miyabi, I assume the 3.5 has a similar "house sound". If you are familiar with the others, how does the Mofi compare to the Standard/47 with regards to sound, build, etc.
Thanks for any input.
TONEPUB
Re: Mobile Fidelity Carbon 3.5 cartridge review
« Reply #1 on: 23 Sep 2008, 03:26 pm »
Yes, I would say it is very similar to the 47.  That was why I was so excited about it
in the first place.  From what I understand, they were just in somewhat short supply
at the beginning of the production run.
Great cartridge though!  Good detail and very neutral.  Definitely one of
my favorites....
chosenhandle
« Reply #2 on: 23 Sep 2008, 05:53 pm »
thanks for the quick reply. I also like the Miyabi sound, really liked the 47 sound, but was turned off by the plastic non-threaded body.
Hopefully MusicDirect will have one at the RMAF and I will have a chance to hear it (finally!).
Thanks again.
TONEPUB
« Reply #3 on: 24 Sep 2008, 10:45 pm »
Or if you want to buy one from SoundstageDirect, they will offer the
10% TONEAudio discount...
Just type in "TONE16" at checkout.  That's 350 off, good for at least
a few albums!
