Off Topic Question - CD Burning
0 Members and 1 Guest are viewing this topic. Read 2889 times.
RGordonpf
« on: 21 Sep 2008, 05:45 pm »
Hi Guys,
I have finally decided to join the 21st century and burn some CD-Rs with tracks from my favorite bands.  Try as I might, I have not been able to burn CD-Rs that sound as good as the original CDs.  I rip the tracks to uncompressed WAV files using EAC.  I have used both the burner software in EAC itself and in Nero 8.  I have used two different computers with drives made by different manufacturers and I have tried burning speeds from slow (4X) to medium (12X) to fast (24X).  I have also used two different brands of CD-Rs.  No matter what the combination, the music on the CD-R always sound thinner, with less ambiance, and with lessened harmonics around each note.  I had two friends come over and listen to some of the CD-Rs versus the original CDs and they heard what I heard.
Am I incorrect in thinking that if done properly CD-Rs should sound as good as the original CD?  And if the CD-Rs can sound as good as the original CDs, what am I doing wrong?
 Any assistance would be appreciated.  Thanks.
John Casler
Re: Off Topic Question - CD Burning
« Reply #1 on: 22 Sep 2008, 02:35 pm »
Hi Guys,
Hi Roger,
I've never heard a difference between "stock" versus "burned" CD's unless:
1) They were burned on a better CD (Memorex Black sound better I think due to less "scattered" laser light)
2) The new CD's were treated with a green pen (again a dispersed light thing)
I have heard a bigger difference using the Bedini DUal Beam UltraClarifier.
RGordonpf
« Reply #2 on: 22 Sep 2008, 05:11 pm »
Hi John,
Thanks for your reply.  I agree with you that the CD-Rs should sound as good as the original if not better due to EACs error corrections.
One of the two brands of CD-Rs that I am using is Memorex Black.  Since my friends hear the same diminished sound quality when playing the CD-Rs I know that the problem is not me.  If no one else has any suggestions I guess I will try using a different ripper, though EAC is supposed to be excellent.  If that does not work, I will have to try another CD player.  It would be weird if my modded Sony SCD-1 was the problem as it seems to play everything else just fine.
RGordonpf
« Reply #3 on: 23 Sep 2008, 02:22 am »
Hi John,
Problem solved.  The drives on both of the computers I used were malfunctioning.  I used a 3rd computer to rip and burn the same tracks and the CD-R sounds just like the original CDs.  What are the odds of two drives on two different machines functioning, but not accurately reading and writing.  Aren't computers wonderful.
John Casler
« Reply #4 on: 23 Sep 2008, 04:27 pm »
I hate when that happens.  :scratch:
Hi John,
