Jim, can a Clarinet be reconfigured as an Octal line stage?
0 Members and 1 Guest are viewing this topic. Read 1241 times.
tubesforever
I know you were able to reconfigure the C2 as an Octal.  Can similar simple changes be made to reconfigure the Clarinet for octal tubes?
Can you tell I am eager to explore a new project?
hagtech
    • http://www.hagtech.com
Re: Jim, can a Clarinet be reconfigured as an Octal line stage?
« Reply #1 on: 21 Sep 2008, 07:08 pm »
Yes, I'm sure it can be done.  If you choose something like a 6SN7, then you'd probably want to run at a higher plate current.  Maybe not, if you want a warmer sound.  Bias resistors would have to be adjusted.  Power supply too.
jh
