Excellent Vintage Denon DP 30L II and Dynavector Karat Ruby - SOLD
0 Members and 1 Guest are viewing this topic. Read 8255 times.
John Casler
Still holding this table.
It is a Denon DP 30L II
Cartridge is one of the original Dynavector Karat Rubies, with LOW hours, since I used this as a second table to "blend" cuts on cassette tape mixes.
Type: Very small size moving coil
Output voltage: 0.2mV / 1kHz / 5cm/sec
Frequency response: 20 to 50,000 Hz
Channel balance: 1dB (1kHz)
Channel separation: 20dB (1kHz)
Compliance: 15cu
Impedance: R = 30 ohms, L = 80 microhenry
Stylus: 0.1mm x 0.1mm, line contact naked diamond
Cantilever: 0.4mm x 0.4mm x 2.5mm, oblique cut solid ruby
Vertical tracking angle: 20-degrees
Tracking force: 1.5g +1.0g –0.3g
Height: 17.5mm
Weight: 5.3g
This is the perfect "entry" TT since it is simple easy and quality.
Looking for $199 for both table and cartridge plus shipping.
« Last Edit: 20 Sep 2008, 09:56 pm by John Casler »
RodMCV
Re: Excellent Vintage Denon DP 30L II and Dynavector Karat Ruby
« Reply #1 on: 20 Sep 2008, 06:06 pm »
PM sent,
Rod
John Casler
« Reply #2 on: 20 Sep 2008, 09:56 pm »
SOLD
Thanks for looking
