Can you use a power book with external monitor, but closed?
0 Members and 1 Guest are viewing this topic. Read 2548 times.
TONEPUB
I use my Dual Core power book primarily as a desktop machine, plugged
into a 30" Cinema display.  I was wondering to minimize use on the LCD
that came with the laptop, is there a way to shut that screen off, or better
yet, use the power book closed, but with the external monitor still on?
Thanks!!
wilsynet
Re: Can you use a power book with external monitor, but closed?
« Reply #1 on: 20 Sep 2008, 05:51 am »
This Apple knowledge base article shows you how:
http://support.apple.com/kb/HT3131?viewlocale=en_US
TONEPUB
« Reply #2 on: 20 Sep 2008, 06:22 am »
Thanks for the try.
That works on a G4, but for some bizarre reason does not work on
an intel based Power Book...
I'll keep looking!
low.pfile
« Reply #3 on: 20 Sep 2008, 08:17 am »
Jeff,
I use a mac book pro intel core 2 duo everyday at work with a separate LCD monitor (and a CRT last year).  90% of the time my MBP is powered on but sleeping (closed) when I connect all my cables: power, ethernet, power, USB (KB) and DVI. Then I just touch a key on the KB or move my mouse and the display powers on. been doing this for years and with a G4 PowerBook too. I have also connected the cables when my MBP is powered on and open then I close the MBP screen and touch the KB just like above.
One thing I can think of...If you have a wireless mouse and wireless keyboard that may be an issue for the MBP to sense these are active.
Another possibility is not having the power connected to the MBP-that usually prevents the external monitor turning on.
I do remember that there were some coworkers who have had some issues with closed macs not waking up. it was resolved somehow. I could check next week if your issue still persists.
ed
wilsynet
« Reply #4 on: 20 Sep 2008, 10:44 pm »
I use a Macbook Pro Intel Core 2 Duo as well, previously had a Macbook Pro Intel Core Duo (1st generation), and Powerbook 12" G4, and it has always worked the same for all of these models.
TONEPUB
« Reply #5 on: 20 Sep 2008, 10:56 pm »
Thanks guys...
I must just be the odd man out.  I'll check with the genius dude at the
apple store.  I do not have a wireless keyboard or mouse, so this is
vexing to say the least.
Hmmm.
K.C.
« Reply #6 on: 28 Sep 2008, 01:45 am »
Works on 6 Intel Macbooks and Macbook Pros that I have.
Plug in the monitor and power with the computer closed and asleep. When you plug in the external keyboard it wakes up and uses the external monitor.
