Full Range Driver Speakers- Any Good?
0 Members and 1 Guest are viewing this topic. Read 1274 times.
Niteshade
    • Niteshade Audio
« on: 19 Sep 2008, 11:43 am »
I am not well versed on single driver speakers. How do they work with moderate powered tube amps? Those with and without negative feedback? I have a really cheap pair of single driver speakers and enjoy their imaging and vocal details, but find that they do not have a wide frequency response and tend to muddle busy music passages some. There are VERY cheap and I assume better models have substantially better performance. What have you folks with single driver full range speakers have to say? I run tube amplifiers in the 30 to 50 watt range most of the time.
mike j
Re: Full Range Driver Speakers- Any Good?
« Reply #1 on: 19 Sep 2008, 12:03 pm »
If you do a search on Fostex or on full-range, you'll find a lot of very satisfied listeners. There is quite a following of full-range single driver speakers. :thumb:
Mike
richidoo
« Reply #2 on: 19 Sep 2008, 01:11 pm »
Feastrex D5nf (4" cone) can achieve flat 50-20kHz with a planet-10 "Maiko" cabinet. It is very dynamic, ultra-detailed, musical and exciting. I found that 3W SS 12V car stereo chip was not enough power, and McIntosh MC402 (ss) worked fine but not as fun as tubes. Manley 100W PP tubes were the best sounding so far, while Cary 50W tube integrated sounded shrill and terrible. All are feedback designs. Many people power this driver with 5W SET no feedback amps successfully. It is ~92dB sensitivity, ~14 ohms impedance. Horn cabinet increases sensitivity. These are extremely expensive drivers (entry level $2600/pair) but the performance is enough that it can replace any traditional multiway book shelf speaker with no regrets, except it won't be bookshelf sized anymore ;)  Feastrex' larger, field coil versions can play lower and faster, with prices past $20k/pr. If you come to RMAF you can hear them play at The Lotus Group demo.  The big challenge for me is box design. The drivers are so fast and clear, it is hard to make a box large enough to optimize the bass and still very low resonance to not pollute the direct sound of the driver.
Single drivers seem to prefer current source amplifier. You might enjoy reading this by Nelson Pass:
http://www.firstwatt.com/downloads/cs-amps-speakers.pdf
Rich
strider
« Reply #3 on: 19 Sep 2008, 02:36 pm »
Rich- Great article, thanks for sharing.  :thumb:
jrebman
« Reply #4 on: 19 Sep 2008, 04:22 pm »
Niteshade,
You can probably find more thoughts and opinions on SD speakers over on the Single Driver Circle:
http://www.audiocircle.com/index.php?board=128.0
Jim
