0 Members and 1 Guest are viewing this topic. Read 6185 times.
Probably best to just use a duster or swipe off with a cloth.Don't want to put stuff on, alter the sound.Wood does not need anything. Otherwise there would never be any antiques if it required constant, putting-stuff-in.
http://www.acehardwaresuperstore.com/cabinet-magic-cabinet--woodwork-cleaner-p-2888.html?ref=42If your looking for a DIY type product....try "mayonnaise" as a cleaner/polisher...don't laugh....it works....
You're not likely doing any good putting any emollient or oil on a speaker. Modern finishes are not permeable, nothing is going to penetrate to the wood underneath. If you want to put a little wax or polish on for looks, that's one thing. Just don't think you're nourishing the wood. The best thing you can do for your wood of all kinds is to keep humidity levels from getting too low and keep it out of direct sunlight. Non-catalyzed lacquers are slightly permeable, that's why that type of finish can get water rings and spots. But I still doubt wax, oil, or similar substances can actually migrate through the finish film into the wood. Tung oil, Danish oil, and rubbed wax finishes would be the only finshes that I'd think would be permeable to any degree. You're not likely to encounter these finshes in anything but artisan crafted furniture though.
The finish is a catalyzed 2 part and very strong. All you need to do is wipe them with a damp cloth.
