9B-ST channel module work into 9B-SST chassis?
0 Members and 1 Guest are viewing this topic. Read 1416 times.
23bw
« on: 18 Sep 2008, 05:43 am »
I currently have a 9B-SST with 3 channels.  I need two channels and wondering if I could simply insert two 9B-ST modules into the chassis.  Will this work?  Is this a supported configuration?
Reason I ask is that I've seen some hybrid 9B-ST THX amps where the owner swapped out two ST channels with SST modules.   So they connect the SST modules to their L&R speaker while using the ST modules for the rest.    Now I'm just wondering if it works the other way around too.   ST modules into a SST chassis?
Thanks.
