vpp 1
0 Members and 1 Guest are viewing this topic. Read 2484 times.
anologone
vpp 1
« on: 17 Sep 2008, 02:46 am »
I own a  vpp1 and am currently using an ortofon om-40 high output mm cartridge. I would like to upgrade to a benz micro Ace m. the Ace m has an output of .8mv.
my question is, how low of an output can I go? will the vpp1 be able to amplify the Ace m, or should I just stick with high output cartridges?
Thanks for any and all advise.
Rick
CIAudio
    • http://www.ciaudio.com
Re: vpp 1
« Reply #1 on: 18 Sep 2008, 05:35 pm »
Rick
Hi Rick,
The output level of the cartridge is only part of the equation...the gain of the amp/preamp and speaker efficiency also come into play. Call me and we can figure out what will work for you.
-Dusty-
