Hum Pot
0 Members and 1 Guest are viewing this topic. Read 1739 times.
hmen
Hum Pot
« on: 13 Nov 2003, 02:47 am »
Could somebody tell me what a hum pot is :?:  I've seen the term in a few tube amp ads. Thanks.
rosconey
Hum Pot
« Reply #1 on: 13 Nov 2003, 09:50 am »
:mrgreen: hum pot comes from humbolt county in california :mrgreen: .
i have some couch potato stuff- must be from idaho :idea:
JohnR
Hum Pot
« Reply #2 on: 13 Nov 2003, 10:00 am »
The triode (tube) often used in single-ended tube amps is what is known as *directly-heated*. That is, the filament (the bit that glows) is also the cathode connection to the tube and therefore part of the audio circuit. Examples include the 300B and 2A3. Since the filament is typically driven by (low-voltage) AC power, there is the potential for AC hum to get into the audio signal. The least hum is introduced when the audio connection is through a point that is exactly half-way in voltage to the AC signal going to either end of the filament---in other words, zero AC volts. The hum-pot allows adjustment to get to this condition and thus get minimum hum.
nathanm
Hum Pot
« Reply #3 on: 13 Nov 2003, 06:31 pm »
Ahh so that's what it does.  I had an ASL preamp that had a hum pot.  It was really touchy too.  The 60 cycle hum was always there to an extent.  Kind of a bizarre scenario IMHO, I didn't keep it long.
hmen
Hum Pot
« Reply #4 on: 13 Nov 2003, 09:35 pm »
Quote from: rosconey
  When I was writing the question I knew this would come up. It's good to know I'm not the only one who thinks like that.
