Passive Preamplifier: FREE SHIPPING!
0 Members and 1 Guest are viewing this topic. Read 1348 times.
Niteshade
    • Niteshade Audio
« on: 14 Sep 2008, 08:56 pm »
Most (meaning around 98%) of the power amplifiers made work great with passive preamplifiers and in fact can work better than they do with active preamps. Passive means there are no tubes or transistors involved in the preamp's construction. As a result, NO NOISE can be added to your system. Another perk is not having to worry about tubes, batteries, etc...  Small in size (10x6x3) and easy on the wallet. Just: $225.00 and the shipping is on us. FREE SHIPPING until October 1st to the Lower 48. Reduced shipping expenses everywhere else.
Important Note: Works great with Solid State and Tube Amplifiers
Specifications:
Frequency Response: Well below and above the audible hearing range. (There is nothing to stop any given frequency inside it.)
Weight: 3lbs
Inputs: 2 Switchless Inputs
Output: 1 pair of outputs (L & R channels)
Point To Point Wiring
Color: You Choose!
Web Site: http://sites.google.com/site/niteshadeaudio/Home
opnly bafld
Re: Passive Preamplifier: FREE SHIPPING!
« Reply #1 on: 14 Sep 2008, 09:13 pm »
pictures?
Niteshade
    • Niteshade Audio
« Reply #2 on: 14 Sep 2008, 09:47 pm »
It looks almost exactly like Preamp #3. What's different is the lack of tubes, a power switch, capacitors and the transformer. We're using a black chicken head knob for the volume control now. A different knob can be specified.
Here's a link to Preamp #3: http://sites.google.com/site/niteshadeaudio/Home/preamplifiers
I will update the photos as soon as I get a chance.
